soldiertom
Last August I was given a 45 B that was semi converted to an electric start tractor. After fixing everything I saw obviously wrong and putting it back together from parts gathered and given, I was ready today to try and turn the engine over and see if I could find anything else obviously wrong. We belted it to a 51 VAC and rolled it over without plugs to just get everything freed up. It had been at least 10 years just sitting in a ware house in Nashville following a refurbishment at some time in the last 15 years or so. After a while of rolling the engine over, and verifying that oil was indeed moving around to the rocker arms etc, we added gasoline and spark plugs to the equation and tried it to see if it would fire up on its own. Well it did fire and it would run; but not smooth at all. The engine would just about die then pop pop pop, then just about die then pop pop pop.
Im thinking the gov'nor needs attention. Am I correct? Or could it be a carb issue? I had the carb rebuilt about 4 months ago, and it was put on the tractor in the barn but never ran till today.
What are your thought folks? I appreciate your expertise.
