45 combine jd
Late model #45 jd combine gas engine gone.What jd engines will fit this combine, gas or diesel? It is a square back very late model.
If the seperator drive is v belt (very last ones were) it came with a Deere 180 gas which is the same engine as a 2020 or a 2510. You could also use a 202 gas which is a 2030,2520 or 3300 combine. You also could put any of the same diesel engines like a 202,219,239 ect. If your seperator drive is a flat belt it used a 165 gas engine with the sleeve deck very similar to the 2010 tractor. Tom
