45 Loader Bucket Latch spring location
Could anybody share a pic of where the bucket latch spring attaches on the loader, and if mine is even the right spring? My bucket won't latch unless I do it myself, the spring doesn't help the process at all
<a href="http://s108.photobucket.com/user/weirddeere/media/John%20Deere%2060/IMG_9373_zpsnxacwbdf.jpg.html" target="_blank">
</a>
Brandon
I don't have any pictures, I hope someone will guide you here. I'd get into johndeere.com parts catalogue and check there for clues. There were several different buckets/blades and pitch options on the latch levers themselves. I will suggest that you put a latch spring on both sides, improvising if necessary. Don't ask me why I suggest that! And, of course, you have to be backing up straight pretty fast with the lever in fast drop for the latches to snap fully in. If you're using one with its original low pressure cylinders, Deere still has the rebuild kits I think. If they still do and you have a LP system I'd buy two because I don't think they're going to have them forever. Good luck!
Brandon,
The springs fell off mine some time ago, never worked real well. I will try to load some manual pics. Shows two springs.
Looked at my working loaders and my parts loaders and did not see where that latch spring had been attached to the boom frame. I did have the larger return spring on one of my loaders at one time but the spring and attaching spring bracket are long gone. If I had seen your set up I would have a pic in my "farmer added options" file for sure. LOL
