dslfarmer
I have a 450check diesel that the starter isnt working on. I wanted to pull start it and get it moving, it ran out of fuel and now I cant get it to start after putting fuel in it. Anyone know or have any ideas. Thanks
yes, for sure need to bleed system. otherwise it will never start.
you need to start at the sediment bowl, but make sure the fuel is at least over top of filter level in tank.then bleed aux. filter or the rearward one.
then start engine and run on gas and bleed final filter or the front one.
then advance the throttle a bit and bleed injectors.
then flip to diesel and go to work.
(quoted from post at 08:51:06 11/25/12) yes, for sure need to bleed system. otherwise it will never start.
All that times 2.
