Good evening all.
I have a Farmall 450 diesel that you all probably remember. For a while it has had the issue with intermittent hydraulics. I am lead to beleive that it is the flow control valve, springloaded on the side underneath the plug with a snap ring. I believe this because while playing with inserting it back in, sometimes it will get stuck if not at the exact right angle. If I take this out, really lube it up, put it all back together, and start the tractor again, it has a chance of working. I originally looked at the screen when the issue first arose and it seemed to look fine. I haven't looked at it since and have much more knowledge about it now, but it is still the same symptoms. Playing with the valves to build pressure does give powersteering or hydraulics at all. Occasionally after a while on rides down the road I'll all of a sudden, without playing with anything, have hydraulics again. Is there a way that I can remove this system (It should be a ps priority if I remember correctly) and still have all hydraulics? Or is there an easy fix or possibly something I am overlooking. Thanks, Ryan.
