Ronald Wright
Well, the generator is working great after getting new brushes and springs installed. The problem now is NO regulation of voltage output.
Generator: Lucas 22756H 37 72
C40T 12V
Nothing identifying if it is 11amp or 22amp. I assume 22 since it is installed on a 1969 4500 that it would be 22amp?
Regulator looks like what is in the manual on the OUTSIDE, but it appears NO adjustments can be made on the coils/contacts. So, nothing in the manual helps at all on what or how to check anything..
Anything above low idle and the voltage keeps climbing right up to over 16 Volts. Shut it back down to idle quickly..
So, I need to know what amp hour the generator is and what regulator to purchase. Any suggestion on where to purchase would be helpful also.
Any other suggestions would be well appreciated. I'm so close to being able to run this thing again and then this happens!! Oh well, one more hurdle to climb.
In the meantime, I'll just disconnect the generator and run it without it until I resolve this charging issue. I did discover that if I unplugged the generator that the generator light on the dash stays on with the key OFF. Plug the gen back in and the light goes out.
C40T 12V
