Ronald Wright
Just had the generator rebuilt on a 1969 Ford 4500. One brush was gone. Reinstalled generator and I have tracked down all the wiring to make sure it went where it is supposed to go (at least according to the drawings and pictures in the manual)..
I understand you should "flash" the generator. I've seen several ways and none make much sense on how to actually do it. They at least agree to disconnect the regulator when flashing.. BUT, the manual states below:
The method in the "manual" says to disconnect F from the regulator. Touch it to Terminal B of the regulator. Momentary touch will polarize the generator..
Is the "ignition key" in the on or off position when doing this? Where is the power coming from at the B terminal if the key is "off"..
My regulator could be the culprit also?? How can I make the generator run "wide open" just to confirm it is working without the regulator?
I'm close but still not working correctly. HELP..
