This is long but I think it lays out everything that I
would do prior to determining the tractor has to be
split to finalize diagnosing the problem.
To avoid doing a lot of things for nothing first double
check the gearshift.. locked in two gears thing. When
gearshift is in the neutral position where it can be
moved side to side make sure the tractor rolls freely,
then move the gearshift into any gear. Then as is
obvious the mesh of gears should now not allow the
tractor to be able to be rolled. It is a good idea to
actually place it in all the following gears and test for
locking and free movement in neutral, reverse, 1st, 3rd
and 5th. For those that are wondering why, this will
help verify that a shift fork has not broken off and fell
into the gears on the trans bottom shaft and somehow
locked them. Now again put it in neutral and verify it
again rolls free. Now start the tractor and test letting
the clutch out to verify it kills or drags the engine down
and will not move. Now pull the TA lever back and try
letting out the clutch, hopefully you will verify that it is
still locking and the results are the same, turn engine
off. Now block the clutch pedal down and leave the TA
lever back, place the transmission in 5th gear shifter to
the right and pull back towards the seat. Now put a
man on each rear tire and with all your might rock the
tractor back and forth against the slack in the drive
train and see if you can get it to break free, make sure
the brake is not set If no result proceed by doing this
which is kind of just for giggles, remove the TA dry
clutch cover. In the attached link go to Chassis and
subsection 267, key 8. Keeping the clutch blocked
down and TA lever back and trans in neutral pry on the
clutch section in there to see if it will turn. Look around
in there for broken parts that may be jamming up the
mechanism. Particularly looking on the front side
where the throw out bearing is, work the TA lever back
and forth to check for anything peculiar. If nothing is
found there I would move on to removal of the belt
pulley drive under the fuel tank if it has one. If not
remove the block off plate, refer to Chassis and
subsection 281, key 16. Now this may let you see the
actual problem, which is something that almost has to
be a bearing is locking the shaft that the gear closest
to the front sets on. If that seems to have some
rotating movement then it may be the lower
transmission shaft has locked, again pry trying to turn
the top shaft looking for any movement of the bottom
shaft. If that seems to be free you may actually be
looking at a very unusual failure. Refer back to the link
subsection 267 again and remove plate key 6. This is a
last ditch effort to see something out of the ordinary.
The section in the front is the PTO drive gears. The
actual shaft that the machine clutch ..pedal.. drives is
inside the hollow area of the gears driving the PTO, so
really nothing can be seen in that area but check for
any oddity. The rear section is the actual TA reduction
section. I am not sure but I believe as JANich said a
failure in there would just turn everything as a unit and
the tractor would just drive in direct range. These
things are built by humans and are not perfect so just
about any unthinkable failure is possible. From this
point you will need to split it for further diagnosis.
CNHI Farmall 450 parts diagrams
