45w on a 1956 "60"
madmechanic
I just picked up a 45w loader for my 1956 John deere 60. How would you pipe in the feed and return line? It has factory Power Troll. I just don't know what ports to use. Any help would be appreciated. Also I'm using a 2 spool valve as it is not a trip bucket.
Ideal way would be to insert the 2 spool valve supply/return lines in place of the rockshaft supply line IE make hyd oil flow through spool valve to get to rockshaft.
Are you planning on using the rock shaft also? If you are there are two plugs on the right side that you can put fittings on put they will need valves to turn off to use three point.otherwise just hook the lines to the powertrol return line to one, pressure in other.push lever forward or backwards. As needed
