46 A compression
JD5460
I looked at a 46 "A" with average paint, new 12.4x38 Titans, rebuilt mag, gears seem o.k. clutch also. Compression 70 psi both cylinders. Is this low? I thought it should be closer to 100. Any one have an answer, I would appreciate it. Guy is asking $2600, good or bad? Thanks
think that is ok for a 46 a cant recall what the spec for it is a late a cyclone series is supposed to be 105 or 110 price sounds fair not a steal but not too much either
If it's a long hood then make sure it has all the sheet metal that goes with the long hood especially the sheet metal ring that goes around the flywheel and the tube that goes to the generator. Also the hardware that goes at the bottom of the castiron dash.
--Walt--
