460-560 Farmalls
big tee
Reading John B's post about 460 and 560 rear end troubles the other day reminded me of my neighbors run at the big tractor pull at Tomah, Wisc. back in the 90's. He took some teeth off of the one of the gears and the chunks got between the case and the gears and broke the case which in turn split the tractor in two pieces. Some people say the bull gear and heifer sprocket didn't mesh. He took a heck of a ride--kissed the hood and ended up on the ground. Turbo, Alcohol and stock gears don't mix! After that they put ladder bars on the side of all tractors which held them together--called them "Lundry Bars" after my neighbor for years. There is a video on U-tube somewhere that shows the wreck--watched it many times in slow motion---Tee
It broke--He got launched
Kissed the hood
End result
He is lucky to have not been badly injured . I have read quite a bit of criticism of 560s for that reason. I own 2 and really like them. My gas 560 has been one of the most dependable tractors I have owned.
The biggest problem was they put 60 horse on an M rearend with the ball bearings. The update from what I understood was they put roller bearings in place of the ball bearings. Once that was done then they were fine. You just don't always know if it has been done to the one you buy for sure. Now days they would be fine since they are mostly now a putter tractor running augers or light work not many plowing hundreds of acres like in the early 60's late 50's.
