460 Farmall
Tom jd50
I was wondering if anyone knows where you can get the rubber hose that goes from the oil bath air cleaner up to the pre-cleaner. I was told it's not available from Case-IH any longer. Any help would be appreciated and Thanks in advance.
Take your caliper, or tape measure, and go to a part store and buy a radiator hose or, take it off, and take it with you. They have straight hose they can cut to length!
I think that is an elbow with different size on each end and that is going to be a real problem. Will require some Jury rigging.
hey i work at international and on either a DT466 or a late T444E there's a water hose that goes from the surge tank to the water pump and its 2 different sizes. You might check it out if your near a International dealership.
The part you need I believe is 370225R1. Appears to be NLA as you stated.
It is 2.25" ID on air cleaner end and 2.50"ID at pre cleaner end. It is 7.40" IN LENGTH.
I have found flex hose with different diameter ends at NAPA and other parts stores in the past. Be worth a try.
In diagram it looks like elbow is tight bend. Flex hose if you find one with the two size ends can be difficult to bend sharply. Hope there is room under there if you find a hose that is correct size.
Years ago, before computerized parts counters, GATES had a catalog of every shaped, curved hose they made. VERY HELPFUL. Perhaps you can find a hose with the correct diameter ends, with a curve or two. Dissect the hose and splice the appropriate segments back together with exhaust pipe inside and hose clamps on the outside. Not OEM, but serviceable.
