460 fron tires
Mikemes
I have a farmall 460 with a 560 wide front end. I'm running harvest king 6.00-16 tires, 6 lugs. I would like to run 8.00-16 tires. Does anybody know where I can get 8.00-16 rims? I'm ok with buying new if I have to.
thanks.
Might be worth searching for an 8x16 rim under John Deere part number AL55753. Abilene Machine also lists that rim for International tractors, and Yesterday's Tractors carries it under part number 122656. Could give you another lead.
Before ordering, compare the mounting dimensions with your current rims. With that 560 wide front, check the inside clearance too and make sure nothing rubs when you turn all the way in either direction. Also check what rim width the tire manufacturer recommends for the 8.00-16s you're considering. Do you know the width and offset of your current rims?
The bolt pattern is only part of the fit.
