C. Oliver Teitz
Is it possible to disconnect the hydraulic hose from the hydraulic pump, run it to a two spool, two way loader valve with pressure relief valve, and then run the out side of the loader valve back to where the hydraulic
hose from the pump originally went in? You have nice valves for your loader and can still use the hitch and two factory valves. You have two pressure relieve valves though. Any problem with doing this?
