4600 Ford Transmission
My 4600 Ford backhoe transmission oil gets hot after a few minutes of use. Also milky colored. I thought maybe water in fluid (it sits outside) so changed fluid but did not change results. Also have flushed cooler, replaced filter. Any suggestions as to what I might try next?
Does it have a torque converter?
A gear transmission shouldn't get hot that quickly but it will get hot eventually.
As far as the milky fluid is concerned... keep flushing unless it's just foaming from cavitation. Need some more info as to what transmission it has.
Rod
