4600 vs 7' Bushhog
It will handle it if the cover is not too heavy and/or you do not try to mow to quickly.
You will likely need front weights if you have steep ground and/or you plan to lift the mower on up slopes.
Dean
Depends on what you're cutting... In most situations it should be fine. In very heavy cover you may need to take a reduced width cut. We have a 6' on our 4000 and it works the snot out of her in heavy grass/weeds/alder. In light going you don't even know it's there.
Rod
ditto what the others said. especially on the front end weights. my 4600 has a old and very heavy servis 6' (rhino ) mower on her. as sais. if cutting down thicket.. it works her. in regualr junk. don't notice it.
weights will NOT be optional...
