4620 3 point / lift problem
hoping some folks here can help with a breakdown i got today - i put the 4620 to work for first time, all went well but while ago the 3 point lift stopped working completely and the 3 position dept control lever jammed at same time.. i managed to get lever moving again but still no lift - the rockshaft? hosing where lift control lever connects into seems to be making a strange sound? all other hydraulics working ok
I'd suggest a problem in the rockshaft control valve housing; cam follower may be off track. You MAY be able to identify problem by removing plug in rear (1/2 inch drive breaker bar) and looking inside while shining a light from above thru filler opening (I found it helps to remove pipe nipple). A service manual would be a big help.
thanks.. i have the manual but im still a little lost, its strange the way it stopped working out of the blue! does the noise coming from rockshaft valve housing tell anything?
The noise and failure to operate probably indicates blown rockshaft valve control o-rings. Look in the hole that thurlow referred to and see if you can see spraying oil with 3pt lever in raised position and engine running.
thanks tx jim, would it be normal for orings to fail suddenly like that? i looked at tractor while ago along with my parts / service manual but cant locate the nut you describe?
thanks I will take another look tomorrow morning.. should oil escape from there when I open it up? I had a 3m power harrow on the 3point.. didnt seem to stress the old girl too much but the lift control lever was getting a lot of use lifting the harrow at each headland etc
still having no luck locating this plug / bung.. the only possibility is it could be the place where there is a return male hdy fitting going back into transmission.. could this have been screwed in in place of this plug?
The plug is to the right of the 3pt centerlink attaching bracket.
Part Number: R27483
Part Price: 8.50 USD
Description: FITTING PLUG
Weight 0.20 LBS 0.09 Kg
Thread Size 1.125 IN
TPI (Threads Per Inch) 12
Thread Length 0.626 IN
Length 0.811 IN
Square Size 0.511 IN
Diameter 1.375 IN
excellent, thanks for that TX Jim,yep my 4620 has a male hyd end screwed int that hole, prob meant as a return oil line.. I'll remove that soon as I can and see if oil sprays out with engine running and lever raised
