Ireland.29
I will probably need to do some engine work in 2012 and I need some help from you guys to figure out what I need to do.. The engine is dyno"ing at 139 so power not a problem but it does smoke a lot before the turbo kicks in, it uses about 1 gallon of oil per 60 hours and starts very hard when cold, its already got new injectors and IP. Oil pressure starts out around 45 and drops to 25 when very hot (at idle) but it holds over 40 all the time at 1700-1800rpm.. so I know I will need to take the head to a shop to test specs but what should I do with the engine - how do you decide on in frame vs overhaul? and would replacing bearings without touching the crank do anything for oil pressure? (even though i guess its not too bad as it is?) and do you guys do any work on camshafts during rebuild? thanks in advance!
