4620 Hydraulic Leak
4620 developed a high pressure leak / blowout last night, I am tryin to figure out exactly which pipe is leaking but it looks like a rubber pipe around 1" diameter passing behind dash / cowl close to back of ignition switch and seems to be going into the top cover underneath the cab floor, any ideas what this could be?
If it's the pressure line to rockshaft housing it should be a steel
line someone has replaced with a hose. OK for a quick fix but hoses
just won't fit where a steel line was.
