Went and helped a neighbor today pull his 464 out of the weeds. Has not run for 2 years. He said the clutch was stuck when he parked it. Could start it in neutral but would grind if you tried to put it in gear or he could start it in 4th but would
need to shut the tractor off to stop. So this is what we found today. Installed new battery and tractor would not turn over. Starter tried, put tractor in 4-hi and pulled with truck and it just dragged the rear tires. In Neutral it would roll. Motor
Stuck? We were not trying to get it to start just checking to see if motor was free. I would also assume the clutch is still stuck as pulling the tractor in 4-hi with clutch depressed it would still drag the rears. 1 Freeze plug was also popped. Need some advise on where to start if at all.. Tractor is in decent shape but who
knows what else we may find.
