my pto will turn, but I cant get it all the way engaged, it will go about 3/4 of the way to lock in, but wont lock, I tried to have someone hold the level back, trying to get it engaged under the seat area. Anything else to do? Thanks in advance
Hi, usually it is junk that has got down behind the seat, next spray your favorite penetrating oil on the PTO lever mechanism all the way from the lever across behind the seat and where it goes to the actuating valve on the MCV behind the hydraulic filter.
If that does not work you may have to gently lift the rubber boot covering the actuating valve and spray it. There is an adjustment on the lever.
JimB
