466 camshaft specs
I would consider a re-ground cam and re-ground or new lifters.
Has every lifter been numbered so it returns to the same cam lobe ?
I am curious what are you doing exactly. That is usually only information that is needed if you have a custom ground cam and are doing performance work.
I am guessing you know how to degree a cam so I won't have to explain it.
I measured one once out of curiosity. I came up with 107 degree intake centerline when installed on the timing marks.
