bob from ill
Hi. Just wondering if the sickles are to ride against the bottom of the gaurds. if they are, how do i make this possible. do i remove shims so the holddowns are tight against the top of the sickle sections. or can the guards be bent up to make them tight against the bottom of the sections. I have replaced all knives and it still cuts rough. then i have had to replace sickle bolts and have hay stuck in guards. that was when i noticed there was a gap btween sickle blades and the bottom of the guards. My hay field has a few dips and humps in it. Is there a way to set the cutter so that it doesnt dig into the ground. Other than using cylinder limiting collars. Thanks
