47 b hydraulic outlet
alfrehner
I recently acquired a 47 b. I want to put pioneer style fittings on so that I can use it with some of my implements. It has the original plugs that screw in, and I've seen where there are those same style plugs that you switch out that have a way to thread an outlet on, but I don't have those. Is there any other way I can plumb a couple of outlets on without using those original plugs. Sorry I don't know what they are called so I am calling them plugs. Any help would be appreciated. Thanks
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Is there any other way I can plumb a couple of outlets on without using those original plugs.[/i:654c4848f0][/b:654c4848f0]</font>"
Yes.
Take a look at the POWR-TROL VALVE HOUSING diagram below.
a268365.jpg" width="650"
Note the plug (Key 19).
If you want "[i:654c4848f0]to put pioneer style fittings on[/i:654c4848f0]", then remove both plugs and plumb from the side of the POWR-TROL.
Take a look at the photo below.
a268366.jpg" width="650"
Hope this helps.
Yes, "[i:654c4848f0][b:654c4848f0]leave number 25 in[/b:654c4848f0][/i:654c4848f0]" and do not "[i:654c4848f0][b:654c4848f0]do anything different with them[/b:654c4848f0][/i:654c4848f0]".
