47 B Transmission Diagram
Guys,
Tore down my transmission on my 47 B a month ago due to breaking 3 gears while mowing this past Fall. I assumed the mower had a grade 0 shear bolt. Ohhhhh Nooo. Got the gears now, ready to put back together. It's been over a month since I dissembled it and my memory is about as long as the tip of my little finger to the first knuckle (I know what you guys were thinking) since turning 68. My IT manual is not detailed enough and the on line JD parts break down when printed is blurred. Looking for a good clear diagram. Thanks
(quoted from post at 09:29:26 12/31/22) Guys,
Is your serial number below or above 201,000?
Do you need only the transmission drawing, or the PTO parts drawing, as well?
Dunno if these are clear enough to help?
If you read my post, you'll note I did that. The on line parts looks to be copies of the book and when you print it out it's so blurry it's difficult to make out.
I have used bar mowers on the Deere for years without an over running clutch, Now a rotary might on some be different but on the rotary mower I had did not ever see a need for one.
