47 Case VIA Hydraulics
Ronie
Hi, new here and I have a problem. I have a 47 Case VAI with an Eagle hitch and the lifting arms will not go down with the pump running, when I shut off the motor and move the up/down lever to down position they go down fine. Also with the pump running and I move the lever to the down position, the arms lift slowly. I put a new single acting hydraulic valve on it and that didn't help. Any ideas would be appreciated.
(quoted from post at 13:19:24 04/24/23) Hi, new here and I have a problem. I have a 47 Case VAI with an Eagle hitch and the lifting arms will not go down with the pump running, when I shut off the motor and move the up/down lever to down position they go down fine. Also with the pump running and I move the lever to the down position, the arms lift slowly. I put a new single acting hydraulic valve on it and that didn't help. Any ideas would be appreciated.
Never mind, it's working now.
Hi Ronie. Welcome. Glad your tractor fixed itself, LOL. Scroll down and find the CASE board and check out all
of the info on the previous pages. There are a lot of knowledgable people on there as well. Bill
(quoted from post at 06:08:12 04/25/23) Hi Ronie. Welcome. Glad your tractor fixed itself, LOL. Scroll down and find the CASE board and check out all
I will, thanks.
