48 8N 6V positive ground
Lmorris
Accidentally hooked 1 amp maintenance charger up backwards for
30 minutes. How many problems did I cause? Thanks in advance.
(quoted from post at 19:55:04 12/26/20) Accidentally hooked 1 amp maintenance charger up backwards for
30 minutes. [color=red:15dacdc72a]How many problems did I cause? [/color:15dacdc72a]Thanks in advance.
None if the charger is intelligent and most modern ones are.
TOH
Do you mean a float charger like the DELTRAN Battery Tender Jr.? As stated most decent units won't work in reverse. You always connect a charging source POSITIVE to POSITIVE and NEGATIVE to NEGATIVE no matter if you use a POS GRN circuit. Did it start after you did that? Yes? Then you did no damage, only a bruised ego.
BATTERY TENDER JR (6V) BY DELTRAN:
Tim Daley(MI)
None if your charger is protected. If not, the charger may be damaged but the tractor systems are fine.
Dean
