48 JD B rear wheels
JohnDeereB
have a JD B 1948 need to move rear wheels in some because they are to wide to fit between fenders on our trailer. Any tips on best way to do so before I start
Thanks in advance
If you can drive it, take the clamps off of the hubs to get it loose from the axle. once loose, jack tractor up and wiggle assembly in. If part if the axle is sticking out, find a pipe to slide over with a
heavy plate welded on opposite end and start swinging a sledge hammer. Good luck. Just don't get in a hurry take your time.
Use a 1/4" chain, wrap it around the axle and through opposite holes in the wheel, with it jacked up just turn the wheel to tighten the chain. That's how I move the wheels in on my 48 A
