480-694-7649
does anybody know where i can find a brass part for a jd A carb. if you take the big nut off the bottom of the carb it has a spring and a brass tube that should fall out. the tube is about 1/4" in diameter and has a bunch of little holes around it and sticks up into the throat of the carb. does someone make these or are they available from a dealer or other supplier? thanks for the help
Its called the main Nozzle. Deere has them as well as YTMAG. Davenport tractor. Formerly known as deerely departed. Carburetor specific.
