484 Dim switch wiring
Paulietools
Hi all. New here with a 484 we bought for our small horse farm. Its got approx 5200 hours. Runs great but all the wiring was hacked up by the PO.
I have bought all the manuals I can find and none of the wiring shows the dim switch.
Does anybody have a good diagram they can share or maybe a picture of theirs wired up?
Thanks.
It should be one position of the light switch I believe. Look for the switch positions on line. I found it for my 806 when looking at wiring in a couple LED lights on the front. Mine was so hard to see I gave up looking and found the positions that way.
Hello Paulie welcome to YT! The CNHI parts diagram for
the Notth American version shows a ..dip.. switch which is
the European word for head light dimming. In the link it is
number 18, if you are viewing this on a phone you need to
click the picture icon at the bottom to see the diagram. The
switch is only available in limited stock, which requires
calling a dealer. The wiring diagram I have also does not
show the connections for it. If the wiring is chopped up
short of buying new harnesses, you will probably just have
to compromise and work with what you have. I am all for
having something work as it did originally, but you have to
weigh your options as to how deep you want to go. Explain
more what you a looking to accomplish, for me if I could get
the light switch to power the headlights at at their highest
intensity and also turn them off that would work for me. I
would asked you to post a picture of this but to eliminate
spammers and unwanted pictures this site limits picture
posting until you have a 5 post count.
CNHI 484 dash parts diagram
Thank you all for the replies. The wiring diagram is the same as the one I have in the service manual I purchased. It doesn't show the Dim(Dip) switch in the
diagram anywhere.
I have replaced the headlight switch and it doesn't control the dim in any of the positions. It controls the headlights and the work lights. I have purchased a
new dim switch and it is on the way, the old one was rusted solid.
Please keep the replies coming.
Hi, is your 484 an assembled in Louisville, KY, USA model on is Canadian model that is more like the European models.
What is on the serial tag? Made in Great Britain or Louisville, KY, USA?
Does it have Delco alternator and starter (USA) or Lucas (European)?
The wiring diagrams are different for the Louisville, KY, USA models.
I am guessing your dim-hi/lo- switch is by your left knee at the bottom of the dash, like my 485. It is just going to send power to the headlamp bulbs. 1 terminal on the bulb is low beam, one is hi beam and one is ground. Look at the wires-the left bulb feeds the right, read the numbers, and go back to the switch. I think the switch will have 3 terminals and the center one will be power from the main light switch. The upper and lower go out to the bulbs. The high beam may have an extra wire to feed the dash indicator. As easy as it is all to get to, if the wiring is a total mess, I would run new wires. Put it in loom. The wire from the main switch that is only hot in the 2 far most right position is the headlights, and goes to the dimmer switch. I think the main switch has the flasher built into itself for fender flashers. The tail lamp is only on in the far right most position. Mark.
I can't see the serial number because it hidden behind the loader frame but it is my understanding that these tractors were built in England.
From reading the operators manual it is a later model tractor and it has a Lucas Alternator on it so I am fairly convinced that it was made in England.
Yes you are correct the switch is done by my left knee. The original switch was removed and "stored" in the foot rest toolbox.
The wiring is all hacked up and while I want to restore the original functionality since this will be a working tractor and not a restoration I am fine with adding replacement wiring. I was just hoping for guidance on the wire colors that were originally attached to the switch so i can attempt to locate them under the dash.
