484 international tractor question
Rob VA
Needing some help with the rear hydraulics. Tractor has set for about 4 months in temp control shop the 3 point hydraulic leaked all the way down over that time .when I cranked the tractor up they raised all the way up and won’t move from that position. So next I changed the filter and fluid ….it was dirty Same problem. Any help would be greatly appreciated appreciated
Is external linkage working properly? If draft control handle is all the way to the rear it will go all the way up and position control handle will do nothing. If no issues on the outside then linkage internal is probably the culprit. Three point hitch cover would have to be removed
You might want to try posting about your International 484 down below on the Farmall, International & McCormick Forum down in the Manufacturer section here. Often there are some who follow a brand and don't pay much attention to the General Topics section forums.
