(quoted from post at 16:37:39 04/15/11) Eric.......didja know ittza 2-bolt, 15-min job to remove the 4-nipple frontmount dizzy and change the points on the kitchen table??? ........respectfully, the babblin' Dell
(quoted from post at 16:20:52 04/15/11)(quoted from post at 16:37:39 04/15/11) Eric.......didja know ittza 2-bolt, 15-min job to remove the 4-nipple frontmount dizzy and change the points on the kitchen table??? ........respectfully, the babblin' Dell
That is plain and simple bull crap.....
no way it can be done in 15 minutes from start to finish...
ohn, he might have bought the EXTERNAL coil kit........no hog out required.(quoted from post at 09:13:37 04/16/11) I converted my 1949 front mount 8N to a 12 volt system and E/I using a kit from this site. I think it was worth the money. You indicated below that the kit you purchsed from this site came with a round coil. You should call the parts department to discuss. You may have the wrong kit. Sounds like the kit for a side mount distributor. Once you are sure you have the correct kit Google Hobo Rosser. Go to his web page for a way to gut an old front mounted coil so you can use a round can coil. I got a real 12 volt round can coil from NAPA that has no resister needed painted on the side. As stated if you use that type of coil you do not need a resister. I mounted mine on the right side of the battery box and ran all the extra wires down the spark plug tube. That made for a clean looking job. Good luck.
(quoted from post at 19:46:23 04/16/11) Excuse me? You say that what Dell said was BS & that's not disrespectful? What about the other 6 of us who said it wasn't? Is what we said BS as well?
I don't plan on trying to 'convince' you of anything. If you can't figure out how to do the job in 15 minutes, then anything I have to say will be wasting my time.
As to the childish name calling.....yea, telling someone that their comment was BS is pretty childish.
