49 8n front mount
Bohinny
I need to do some work on my governor. The throttle does not do anything for the first half of scale. What it do i need to fix this the $50 or the $100 kit
thanks
Bohinny
If you have a manual[I&T-F o4],look in it for gov adjustment.If you don't,buy one.Your prob may be adjustment,on the spring it needs to be snug,not too loose or tight,so it will move,but not have any pressure on it.---lha
Spring has been adjusted to the book. There are two kits on this site
1.Governor Repair Kit - Basic - For 9N, 2N, 8N. Kit contains gasket, lower race assembly, ball bearing, C-clip, 3 shims and 4 governor balls (58 inch). (Part No: BOK12502)
2.Governor Repair Kit, Complete - For 9N, 2N and 8N. Kit contains lower race assembly, shaft assembly (with or wo proofmeter), upper face assembly, ball bearing assembly, shim, drive shaft ball stop, governor balls (58 inch), bushings, mounting gasket, dust seal, C-clip. (Part No: CAPN12502A)
I have no idea what the inside looks like i wanted to have the kit so i could get the job done in one day. I figured somebody has had the same problem and might give insite to the parts that cuase this problem. everything else seams to work like it should
Successfully rebuilding an N governor (or the carb or just about any other part) is dependent upon your skill & ability, the condition of the core, the quality of the parts & the consequence of error. A governor rebuild usually isn't a matter of pulling it off & just replacing parts. The shaft/forks could be worn, it probably needs shims, etc. If you're not skilled at that sort of thing, the chances are pretty good that you will be wasting your money if the core is too worn or it needs more or fewer shims than you install. But at least the consequence of error is just the loss of time & the cost of the parts because doing it wrong won't burn up the engine!
You can always pull it off & send it to nnalert's for a rebuild. Give Derek or Don a call for the cost.
50 Tips
