(quoted from post at 00:08:57 02/06/18) '49 9N
Died while running
Acts like the battery is completely dead.
New battery
New Solenoid
Will start and run if the solenoid is jumped.
Starter button is a rod not wires.
I was told it is a '49 9N, so I am not sure.(reply to post at 21:37:29 02/05/18)
(quoted from post at 12:05:03 02/06/18) Does your tractor have a three or four speed transmission? That will tell us if you have a 9N or 8N. Also can you post a picture of your
solenoid?
(reply to post at 12:05:03 02/06/18)
(reply to post at 12:33:48 02/06/18)
(reply to post at 17:32:48 02/06/18)
Thank you for your help.(reply to post at 18:01:06 02/06/18)
Is the button with the rod obsolete with the engine change to a newer year?
(quoted from post at 10:16:33 02/07/18) "Is the button with the rod obsolete with the engine change to a newer year?
No the button and rod should contact the back of the starter switch. Those switches do go bad. Remove it and test it.
(reply to post at 05:30:07 02/08/18)
