495 with no remote valves.
Is there any way to get hydraulic pressure to an open center valve ( loader ) on this tractor?
Should there be pump pressure on the capped line with engine running. This tractor just has 3 point. The loader is mounted, just need to get pressure.
Thank's
Beagle
You're not going to be able to "tee off" of anything to get pressure on that tractor. It has an open center hydraulic system which means the entire system has to be one continuous loop. When you tee in/tee off, you create two loops, and the oil always takes the path of least resistance. It will never develop pressure.
Normally you'd purchase an add the "power beyond plate" to the end of your remote valve stack to get pressure for the loader. Since you don't have remotes, I'm not sure how or if that would work.
I'm going to try disconnecting the pressure line from the MCV valve to the draft control- unloading valve and run that oil thru a loader valve that has the power beyond port. From that port, flow will go back into the draft control- unloading valve and operate the three point. Regular return oil from the loader valve will go back to the tractor reservoir. The loader valve will have to use three ports, pressure in, return and power beyond.
Hi, never seen a 495 without at least one remote valv.
Trace the hydraulic lines from the MCV up and over the top of the hydraulic housing, the smallest line should be the high pressure line and the larger one the return.
Does your loader valve have an IN, OUT and Drain ports?
It will when I get a new loader valve with the power beyond installed.
Jim B2, I read several of your post's going back a few years ago about this subject. Many thanks for posting all your comments as they were very helpful. I don't know why someone would buy a modern tractor without remotes,
Beagle
The Drain port is not a big requirement if you’re loader has double acting cylinders all around which most modern loaders d.
More important on the old loaders with single acting boom cylinders as there was a large volume of oil to return to reservoir when lowering the loader.
