4960 powershift will not move
cjrpr
Hey guys. Got a 4960 powershift. Operator started it up and started driving like normal and then pushed the fwd button and the tractor stopped moving. Hydraulics work fine but no gears. Turned fwd off and still no gears. May have just been a coincidence I don't know. Put lever on tow position and shifted through the gears and no labor sound to the engine. Dont have alot of experience on 60 series. Not many around my area. At first I thought maybe the disc went out in the flywheel. But the Hydraulics would not work if that was the case. What could be causing this?
Could have lost the damper disc. The hydraulic charge pump is driven by a hex shaft seperate from the input shaft
