Anonymous-HT-0-HT
I have my 1500d. I was moving a lot of rock with my little tractor...probably being a little too hard on it in 4wd. basically, when its in 4wd, it sounds like the gears are "slipping"
If I'm in 2wd, no problems, no grinding sounds. If I jack the front end up and spin the front wheels, they sounds tight...doesn't sounds like anything rattling around.
If I put it in 4wd, it actually will give power to the front wheels, but if I put ANY amount of pressure or torque while in 4wd, it makes an awful, grinding, or gears "slipping" noise....
My best guess and hopefully this is a better problem to have is that it's the drive shave thats slipping or lost its teeth...
Does anyone have any experience on if the driveshaft is the weak link and where I would start to figure out where the problem is?
Thanks,
Thanks,
