5 bottom plow identification
Popnascar
I HAVE PICKED UP A JOHN DEERE 5 BOTTOM PLOW. I HAVE GIVEN SOME CASTING NUMBERS TO THE LOCAL DEALER AND HE IDENTIFIES AS A 66H, BUT THIS PLOW HAS TRIP WHEEL AND THE 66H HAS A CYLINDER. I HAVE POSTED A PICTURE OF THE PLOW. CAN ANYONE TELL ME WHAT MODEL IT IS.
Look's like you have JD 66-A (clutch lift) coverted to hyd. lift. Arm & pivet bracket hanging down in front of land wheel is back half of hyd. lift. (used on 5 bot. plow only} looks like front part has been removed.. Check PC- 322 ; on JD Parts .com...
One thing you will have to do before you use your plow is to remove the depth control lever. This is the lever with the linkage going to the clutch unit on the land wheel. It isn't necessary on a hydraulic lift plow. This was a depth stop for use on the clutch lift plow. It will interfere with using a hydraulic cylinder. Hope this helps. Mike
It is a 66 A. I just happen to have a vintage original operators manual for that exact plow. Printed in 8/48 and in excellent shape. Has all the parts listed and pictured also so you can see what you need to put it back original if you want. Also all set-up , operating , adjusting info you need. My e-mail is open. Let me know if interested.
Don't know what you plan to pull it with, but it sounds as if you have a choice as to whether you make it a hydraulic or clutch lift. As romantic as the clutch lift may sound, I have my doubts as to the ability of the ground wheel's traction to generate enough torque to lift 5 bottoms out of the ground. Nothing more "unromantic" than to come bopping up to a headland, pull the rope, and see that land wheel skidding along...
I really appreciate all the replies. I picked up the manual from Randy and based on the information I"ve gotten, I will more than likely get the other bracket and a cylinder and put the plow back as a coverted model if I want to plow with it. I can appreciate the comment on coming to the end of the field and the clutch not being able to pick the plow. I have an F650A plow also that I may use on plow days and just restore this 66A for the parades!!
