CONSERVATIONMAN
- Location
- SE Wisconsin
You can use a shop press with a couple helpers and take the bow out of it.rebuilding a JD #5 sickle mower. The cutterbar has a sag of about 1" in the middle. It also has a bit of a twist.
Should I straighten it? Could I? How?
thanks
Wally
Is it to be used? You really don't want a taco'd slab for that. Adjusting the guards will be a pain in the neck. Already been down that road with my mower.rebuilding a JD #5 sickle mower. The cutterbar has a sag of about 1" in the middle. It also has a bit of a twist.
thanks
Wally
Clamp it in the vise and bend it back. Now getting the twist out is going to be more of a project. How in the world would a bar get a twist in it? Can't you buy them old number 5's for about 50 bucks? I think I would buy another mower for the bar.rebuilding a JD #5 sickle mower. The cutterbar has a sag of about 1" in the middle. It also has a bit of a twist.
thanks
Wally
The new guards & knife might help. I'll be curious to see your results. Should be able to cut lawn with it when it runs right.Yes I use it, if only for cutting weeds but it was clogging so often that I decided to rebuild it. Used when I got it, it had 5 diffrent brands of rock guards that would never get set right.
ordered all new guards and sickle set.
Wally
Probably sprung from smacking the flat, outer end of the bar on something.How in the world would a bar get a twist in it?
