SlowCredit
Have fired the parts cannon and am stuck.
Ran great last two years - this year overheats after running only 5-10 minutes - load makes no difference.
Have installed new water pump, hoses, belt, radiator and felpro head gasket. No love - still boils over after 5-10 min.
Definitely overheating - pulled thermostat to be sure. Water/coolant only to top of coils. Hoses not collapsing - running
it off a bottle - have hood off (after removing/installing about a dozen times...). No shroud, but it's never had one.
Changed oil after gasket - oil looks fine - no coolant.
Cylinder heads didn't look particularlly steam cleaned - old gasket was worn out, but no obvious failure points.
If I start it without cap, I do see some bubbling after a few minutes - then eventually overflow after 5-10.
Warped/cracked head? Not thinking cracked block, as oil is fine - Maybe timing, but runs great and nothing changed from
past 2 seasons. . .
Need to mow. Any/all help appreciated!
Thanks!
Slow
past 2 seasons. . .
Thanks!
Slow
