5000 Diesel oil filter ??
Bought a Ford 5000 diesel. Was told it is a 1969 model. It has not been started in five years but I got it started. Getting ready to change oil and filter and the filter has motorcraft on it but can not read the number. It looks like it say FL-1-A but pretty faded. Is that the correct filter number or what number should I buy? Also, what type of fluid does the power steering use? Does not look like hydraulic fluid.
If you haven't yet, remove the side cover from the inection pump and check for rust. If there is any try to get it cleaned out. spray cleaner or light oil, and try to work rust out with a knife or dental pic or what-have-you. Then change the cam box oil. Same oil as crankcase.
I use a Motorcraft FL-1A oil filter on my 5000 Ford, as a matter of fact I use the FL-1A on my 601, 4000 and 4600 too....
