5000 Diesel overhaul kit
nwford
The 1974 5100 we have is getting tired. Been breathing hard the last couple summers. Plan on keeping this tractor for along time.
Anyone have a recommendation on where to get an overhaul kit from?
Block will need bored and crank may need grinding. Cam bearings replaced. It is best to let machine shop supply pistons and crank/rod bearings if bored and ground. Will need valve seats and guides replaced along with valves.
2X what shaun posted. You don't know what to order until they tell you. They can probably save you good money as well. Go ahead and order your gasket set here.
Was more so asking if anyone had good luck with a certain brand kit. Had issues with several Reliance kits in some green tractors years ago and don't want to go down that road again.
