5000 pto stuck on
norsky 63
I have a 65 ford 5000 the pto is stuck on. I opened the inspection plate on the side of the rearend. The spool was stuck in on the control valve so i got it unstuck and put it back together. When I started the tractor the pto turned slow for a few seconds then up to speed fast. With the control linkage on or off the pto is stuck on any help would be great
You sure the pto brake isn't bad and the pto might not just be spinning without power?
IE.. have you tried it under load?
soundguy
I wedged a 2 x 4 against it and it stopped spinning easy so I guess I'll check the brake. Is it repaceable? Thanks
