Korny
I added a Ford 501 mower to my list of Ford implements. It's been sitting for many years so plenty to go through first including getting a pittman rod. Looking forward to using it to cut corn stalks at the end of the season.
I have a junk Dearborn 14-? junk mower. It has a steel pitman that may fit your mower. Send ne mail on the side(with length of pitman measurement.
Thanks for the offer Charles, but didn't they make these out of wood for a reason? So the wood would break instead of more costly parts? I have lots of old 2x's I can cut.
You need hardwood or they will break frequently. I don't see the several small linkage pieces necessary to connect to tractor, in your picture, so I hope you have them when you are ready to use, or you will be disappointed. They are lose (not permanently connected) to 501 & frequently lost.
Your right. Wood is your cheapest and simplist route. Expierence over the years for me has never broken. or worn out, a steel pitman, only blades break the rivets, while rivets wear in wood, but also never broke.
I,m about ready to send whats left of my Dearborn 14-17 sickle mower to the scapper, so if any anyboby has need for the following drop me a line. I'm in Hastings MI.
7' mower bar, blade, pitman, belt, lift cable, under axle hook up, or all for $75 and pick up.
Charles Krammin
well that does not sound promising. And I was looking at it and wondering what/where the flat piece with the hole in it is for.
Send me an email & I will send you the 501 user's manual (pdf). I do not know of a way to attach pdf files to a YT post. This shows about 5 parts that I see as missing, that are on my 501.
