504 IH runs very rough
bigdieselman
Im working on my neighbors IH 504 utility tractor, hes been sick for 3 years, getting better ask me to get it running. did a complete tune up new plugs points condenser coil, adjusted the valves, cleaned the carburator but it still runs very rough, back fires, smokes wants to die out. I done all I could except pulling the head, I need advice thank you
I'd start by putting the old condenser back in. Next I would make sure the firing order is right. since I know it is not the common 1,2,4,3. IH uses the 1,3,4,2
Was it running bad before the tune up?
After market ignition parts are known for being bad or wrong straight out of the box.
Carefully retrace all components of the ignition, especially the points and condenser, the distributor condition, and spark condition at each plug. Exhaust backfire is a sign of intermittent loss of spark, bad points,loose connection, bad ignition switch.
Do you have a vacuum gauge? Try checking the vacuum and look at the troubleshooting guide that comes with it.
I?m thinking that has a Siamese manifold, which can burn through between the intake and the exhaust. That will act like a bad vacuum leak.
The other thing that comes to mind is dry valve guides, causing slow valve closing, sticking at speed.
Had a very similar problem, in a similar IH engine. The distributor rotor shaft notch had chipped away where the rotor button pushed on. Allowed the rotor button to rotate a few degrees away from the points timing. Ran like crap. One thing you can easily check.
If you by some chance had the distributor out I am going to guess it is out of time by a 180 degrees. If it ran good before the work. Or the plug wires are not on in correct location/order.
