504 radiator bracket
That goes to above water pump front of block. Two bolts, took them out to work on manifold pipes, can't get lined up again. Is there another plate behind there?
Hate it when fix something and mess something else up.
Help appreciated.
Could be a shim with holes, use a stiff #9 type wire with a 1 inch 90 degree bend in the end to get a start on alignment. A same thread bolt sharpened to a point can also get it right while one bolt is just loose , then the pointy one installed, then #1 tightened, then pointy one replaced with original. Jim
I have lots of pictures when I had mine apart. Which nightmare piece are you working on ? I had trouble realigning some rigid brackets as well. May be the same ones. Let me know if something I can help with.
