504 Wide Front end
Hi Folks Does anyone know what front ends can be adapted to fit my 504 i was wondering if you could take one from a 560 or maybe an h or m? Any input would be appreciated! Thanks
(quoted from post at 14:52:20 03/13/11) Hi Folks Does anyone know what front ends can be adapted to fit my 504 i was wondering if you could take one from a 560 or maybe an h or m? Any input would be appreciated! Thanks
The 504 was a descendent of the Farmall C, 200, 230, 340 etc. The wide fronts from an H will not fit, nor will any of the other models you mentioned.
If you really do want a wide front axle for your 504, I can fix you up with a brand new unit from Schwartz.
With enough work and time anything can be adapted to fit. Probably could make an H axle fit with a thick plate to mount on the tractor and bolt the axle to. Needs to be thick enough to counter bore for the bold heats or nuts. unless you tap it for threads.
