the oil pump pick up came loose and sucked air causing the crankshaft and bearings to be damaged hence got crank redone at an engine machine shop, installed repaired crank with new bearings that engine shop supplied, engine runs well but as it warms up it starts to make a noise, not a hard noise but sharp noise that increases with temp increase engine does not overheat.... also this engine does not have sleeves and the bore is now 6 thou larger than the pistons, could this be piston slap or connecting rod bearing noise, when cold noise isnt there? I am puzzled thanks for all input..
