51 A main bearings
Dose anybody know of or have a set of .010 under main bearings ? The owner of the crank took it to a shop to have it polished it came out of a junker and they took it apon them selfs to grind it .020 and .010 . i fuond rod bearings but looking for mains . Any leads would help. thanks
You would still have to start with the proper sized bearing shells. Otherwise you will be .004-.006 in 2 spots and .014-.016 in the other spots around the journal. Not a good situation.
51 A doesn't have shimms, you have to buy new bushings which are undersized and have to be bored to fit even a standard crank, so hopefuly they were undersized enough to fit your turned crank
