'51 B with wobbly front
Was driving a friends '51 narrow front B this weekend and noticed the front end wobbling back and forth unless I put a little pressure on it, either left or right, or turning. If I was just going straight....wobble. Can any one offer advice on common issues that cause this? Good chance I will be doing the work and any help to get me started in the right place would be appreciated.
Worn sector gear. The gear wears in the center in the straight ahead position. If you make it tight for going straight it will bind when you try to turn.
You might be able to turn you eccentric bushing some. If it is not worn to bad one notch might be enough. My A had teeth missing so had to put in new gears, matching set from another A.
A slightly bent rollomatic arm on my 50 made the front wheels wobble real bad on a hard surface road. Changed the arm - no more wobble. It's kinda hard to tell if it's bent, since they are made with a twist built in.
Probably need the eccentric bushing adjusted.
Best tip I ever got was to take the lock screw which has a
screwdriver slot down to the parts store and buy a new
allen head set screw with equivalent size and length threads.
They can be tightened better, and not come loose.
Mike
